Hello:
New to this forum and need help with video display/driver issue.
Platform: 3-month old Dell XPS 420 running Vista Ultimate SP1 (x86) with ATI Radeon HD3450 graphics card, 4Gb RAM, Quadcore chipset.
~1 month ago, started having "blue screen" restarts of the OS (error code 4e) for no reason.
Tech'd via Dell YTT: "bad hardware" -> Dell replaced MoBo memory.
No problems for 3 weeks.
Another blue screen (code 4e again) last Sunday.
Extensive troubleshoot w/Dell (including running Diagnostics, installing and running Windows Debugger, etc): "bad video hardware or drivers" -> installed new(er) video driver downloaded from Dell website AND Dell replaced video card.
~Immediately began having new problem: instead of "blue screen" and Vista restart, now have intermittent loss of video display (goes to pixelated colors, then black, then recovers), the error code 117 ("video hardware") and the error message in system tray: "Display driver atikmdag stopped responding and has successfully recovered".
FWIW, this seems to occur shortly after a reboot or system restart, and even with only browser open (I do not have gaming software, TV tuner, dual monitors or other hardware/software).
Most recent call to Dell (today): they seem to have no clue and advise OS reinstall, claiming the registry must be somehow corrupted (after THEY blundered through the driver uninstall/reinstall/update:sa: and may not have followed the completely correct steps to do all this, from what I read at the ATI site).
After some research on my own, it seems this is a pretty commmon occurrence with Vista and ATI video cards.
I have seen proposed causes and fixes that run an extensive gamut, such as: a MS patch (KB938194), disabling Aero, uninstalling the Catalyst Control Suite (just install video display driver), changing the display color scheme to default, a simple logoff-logon after system start, installing RivaTuner, etc.
I also found an even newer driver suite for this video card on the AMD website and am considering uninstalling the version we installed this week, and replacing it with this newer version.
I'm not a computer-illiterate, but I'm no engineer, and this hardware/driver stuff is a bit over my head, especially with such a range of "solutions" and fixes".
Aside from NOT reinstalling the OS (which my gut told me was NOT going to solve the problem and would only cost me days of lost time and productivity), what has worked well for others with this problem???
(And forgive me if there's already an extensive thread on this; I couldn't seem to locate it...)
Thanks much in advance!
- Dell Studio XPS 420
- Intel Core2 Q6600 (2.4 GHz) w/ Quadcore Tech
- 4 GB DDR2 SDRAM
- AMD Radeon HD3450 256MB PCI-Express x16 RV620
- 20" Ultrasharp 2009W Widescreen Flat Panel
- 640GB SATA Hard Drive (7200 RPM) with DataBurst Cache
- Broadband (cable HSI with Turbo)
