Solved driver for gigabyte-realtek lan
i am looking for the new driver for:
Realtek RTL8168B 8111B Family PCI-E Giga
pitstop states the driver version is
6.208.0729.2008
i have look every where anyhelp
i am not buying a scripition to d/l drivers
any help here
    homegrown
    intel core2 quad Q6600 2.4ghz
    gigabyte x38t-dq6
    4gb ddr3 Corsair TWIN3X2048-1333C9DHX
    nvidia geforce 8800gt 512mb
    Realtek ALC889A codec
    samsung 21.3 screen
    1024 by768
    500gb wd hd 250gb wd hd
    Corsair CMPSU-750TX
    Arctic Cooling Freezer 7 Pro
    microsoft wireless mouse 7000
    microsoft wireless keyboard 7000
    cable 850
    pioneer dvd-rw dvr215d lite-on cd-rw sohr creative inspire pt7800 7.1 plus 2.1 addtional speakers hp officejet j5750
Hi njnitehawk,
According to the Realtek website (link below), the latest driver available is version 6.208 dated 2008/8/25 (2 days ago).
Dwarf
Realtek
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Dwarf
my guestion on this is
i have d/l both drivers for the new upate Both are zip
files when i open winzip
there is no exe or setup folder what do i do???
lost as always
    homegrown
    gigabyte x38t-dq6
    samsung 21.3 screen
    1024 by768
    Corsair CMPSU-750TX
    cable 850
If there is a *.INF file, just select "update drive" in device manager, and go to the inf file.
Why do you want to change drivers?
The Realtek lan normally works pretty darned good, and it's also supported (optional updates - hardware) automatically by windows update.
Hello NjNiteHawk,
This is the same driver I use, and it should have a Setup file to install with when you open the extracted folder from the ZIP file. Are you downloading the "Auto installation program (support Vista 64 and Vista) (Submission ID:1308340)" file?
attachment.php
Brink
thanks for the response
i was going to write to you
but you are always helping so many people
i have the set.exe -but see the snip i am sending
and will the install when i go there will install
    homegrown
    gigabyte x38t-dq6
    samsung 21.3 screen
    1024 by768
    Corsair CMPSU-750TX
    cable 850
This may be obvious, but did you extract all of the files and folders to the Desktop from the ZIP file before trying to run the setup.exe file? :)
yes i have
i am thinking maybe winzip11.2 maybe the problem?
going to work on it
i don't need the drivers that bad yet
    homegrown
    gigabyte x38t-dq6
    samsung 21.3 screen
    1024 by768
    Corsair CMPSU-750TX
    cable 850
You might try 7-Zip as a test to see if it is.
brink
check this out
this from 7-zip
see this snip
    homegrown
    gigabyte x38t-dq6
    samsung 21.3 screen
    1024 by768
    Corsair CMPSU-750TX
    cable 850
You would need to extract the files to your desktop first before running the setup file.
If you did, then your driver file may be corrupted. See if downloading another copy of it will work better.
i think we it a home run with 7zip
thanks
    homegrown
    gigabyte x38t-dq6
    samsung 21.3 screen
    1024 by768
    Corsair CMPSU-750TX
    cable 850
That's great news NjNiteHawk.
