Solved Driver help
genoc
I have the following item and it comes with a cd and website for drivers. I have ran the setup utility for the driver but the problem is whenever I insert the dongle to my usb port, it will say usb device not recognized. In device manager, it is showing as unknown device. I have uninstalled the unknown device via device manager and repeated the steps of uninstalling and re-installing and inserting usb dongle but issue i'm still facing the same problem.
CDR KING
Any suggestions to fix? Are there native usb wireless n drivers for windows vista that I can download somewhere? What could be causing this issue?
Thank you in advance for your expert help.
Hello, are you using an Admin account ? Have you tried a different USB port ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Yes, I did. I also used another port though I have not tried cycling through all ports. It may be worth a try. I will try this tonight when I get home.
Is there like a repository of Vista native drivers where one can download?
By all rights, it should work, try making another Admin account and see if maybe that will work .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Well, excellent news. Thanks for using Vista Forums .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
