	You are using an out of date browser. It  may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
driver power state failure vista 64bit
					flashed blue screen with driver power state failure
could this be due to having three hard drives on the same power cord?
if so thats an easy fix
also its a fresh install in raid 0 config,  ima check for more updates now.
possible missing drivers or power problem power supply should be more then effecient.
					home built
					AMD Athlon 64 X2 4200+
					asus m2a-vm
					2 gigs kingston hyperx
					geforce 9800 gtx/gtx+
					n/a
					samsung led 23 inch
					1280 x 1024
					Two western digital raptor 1005 gb in raid 0
1 tb caveliar black wester digital
					1000 watt modular by ultra i belive.
					apevia
					6 fans
					g500 logitech
					g15 logitech
					cable
					tryed getting minidump files says i need permission and it wont let me zip them ??
					home built
					asus m2a-vm
					n/a
					samsung led 23 inch
					1280 x 1024
					apevia
					6 fans
					g500 logitech
					g15 logitech
					cable
Right click the files & send to zip folder.
Select desktop.
You will then be able to post them on the forum.
					11.3 KB
					HP-Pavilion m9280.uk-a
					ASUS NVIDIA Geforce GTS450
					HP w2408 24.0" (Dual monitor)
					1920 * 1200, 1920 * 1200
BluRay & DVD Weiters
					40 Meg
					it says file not found or no read permission.
					home built
					asus m2a-vm
					n/a
					samsung led 23 inch
					1280 x 1024
					apevia
					6 fans
					g500 logitech
					g15 logitech
					cable
					The driver power state is usually szomething like a usb not shutting down.
Its not to do with actual power, or a hard drive.
I get them because my cell phone isnt vista x64 compatible... So when i reboot/shut down the usb doesnt release.
					Dual L5639 // i7 950 @ 4.0Ghz
					gtx 560 ti // gtx 260-216
					Dual 22" // Headless
					usb card reader not instlled maybe the issue?
					home built
					asus m2a-vm
					n/a
					samsung led 23 inch
					1280 x 1024
					apevia
					6 fans
					g500 logitech
					g15 logitech
					cable
