Solved Dual-Boot with XP (HELP)
AlexRD
Hi there.
I wanted my computer do dual-boot with XP, so i made a new partition called F, and then i ran the XP CD and installed in F the CD. But now, when booting, it only shows Windows XP Professional. Have i accidentally formatted my VIsta? Because my programs from Vista are still there.
Alex.
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    Asus G2s Keyboard from Logitech
    2 MB Wireless Network
Hello Alex,
Usually you would install XP first then Vista. When you install XP second it just removes the MBR boot files for Vista and boots to XP instead. To fix this, you just need to run a Startup Repair for Vista to replace it's MBR boot files.
http://www.vistax64.com/tutorials/91467-startup-repair.html
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Hello Alex,
Thanks a lot , it worked for me.
In the starting, i thought "God ****ing Damnit, i cant belive im going to format again"
and now you saved my time... My hero :sick:
And for Mansrm18 ( i think that is the name xD) thanks for the help, but the startup repair did his job, so there was no reason to use the EasyBCD. Thanks =)
Thanks a LOT :D
Alex.
    Asus G2s
    17" Generic PnP
    1440x1280
Your welcome Alex. I'm happy to hear that it is working for you now.
