I have a new computer with Vista Home Premium x64. I used a dual monitor graphics card in my old computer with Windows XP. Took the card out and install it in my new computer and updated the driver. But, performance is poor. For example I can't use Vista Aero. I would like to buy a new, relatively inexpensive dual monitor graphics card which is compatible with Vista premium x64. Any suggestions?
now presuming that the card you took out of you new system was Nvidia and that your running on a small budget i can now suggest an XFX Geforce 8600GT 512MB DDR2 PCI-E
£58.07 inc. VAT
or if you have a larger budget then you could have an XFX GeForce 8800GT Alpha Dog XXX 512MB PCI-E 2.0
£144.47 inc. VAT
however be sure to read the tech spec's b4 you do go get one
if the card you took out of the new pc was an ATI i suggest that you look at getting an ATI card replacement
be sure it will fit in you case, make sure you power supply meets the requirements
and make sure you have enough spare dims to connect any required supplementary power
Your budget is pretty much your limiting factor...However, that card you have is a *PCI* card as you have listed - does your new computer already have onboard video? If not, you'll be looking for a new PCI-e GA - Depending upon your budget again.
I purchased the eVGA 8800 GTS 512MB JO edition and am mostly satisfied with it, for the money.
Logitech MX Master (shared)
Logitech G15 (gen 2)
Operating System
Lenovo ThinkPad E545
AMD A6-5350M APU
Lenovo
Conextant 20671 SmartAudio HD
Lenovo 15" Matte
1680 * 1050
