Hi guys! I recently built a new computer and am having a quirky issue with my DVD drive and hopefully someone will know where to start. It seems that the drive will read CDs (opening them in iTunes) and music DVDs (playing in Mplayer), but the system completely hangs and freezes when trying to load a data disc. Specifically, the system will continually try and open the DVD (spinning away) and cause serious lag to the computer. When trying to eject the DVD, it will then cause the computer to freeze and require a reboot.
The data discs that I'm using are all programs that I've previously loaded on my XP install, so I know the discs aren't corrupt. I'm also running a 32 bit version of Vista, so I'm not worried about 64 bit compatibility issues.
The drive is a Lite-on (DH-20A4P) IDE based drive, set as Master on the cable. There are no other devices hooked to the IDE cable, and the cable is also brand new (came with motherboard).
Here's the steps I've taken thus far to diagnose the problem -- with no fixes working.
- Downloaded and installed newest drivers for the DVD drive
- Flashed the DVD drive firmware with most current version
- Uninstalled then reinstalled DVD drive through Device Manager
- Disabled autorun feature
- Checked connections from drive to motherboard
At this point, I'm not sure of what else to check. The drive obviously is working properly since I'm able to play CDs and DVD movies/music. It might be worth noting that I used this same drive to install Vista, but perhaps the updates horked my drive?
I'm thinking this is a Vista software issue, but can't think of anything else to try. I'm also hesitant to wipe and reinstall Vista for such a small issue. Any help in figuring out this issue would be incredibly helpful. Thanks!
- Intel Q6600 OCed to 3.2Ghz
- GIGABYTE GA-EP45-UD3P LGA 775 Intel P45
- 4GB Crucial DDR2 800
- Radeon HD4670 512MB
- Samsung 2342BWX
- 2048x1152
- 750GB WD SATA 320GB Seagate SATA 160GB Seagate SATA
- PSU
- CMPSU-450VX
- Case
- Rosewill R5604-TBK 0.8mm Japanese Cold Rolled Steel
- Cooling
- ARCTIC COOLING Freezer 7 Pro 92mm
- 6Mbit
- Other Info
- Homebuilt computer completed in Dec 08 for ~$800
