DVD Drive
Tazman
How do you change an XP dedicated dvd drive ML-dt-st-DVDRRW-GWA-4164b ATA Device, to work with Windows Vista.
All i get is "Your system is not configured for this Drive, an update is not needed." when i try to change the Firmware.
It will run Cd`s though,
Try going to the manufacturer's website and see if there is a Vista driver for it.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
I went to the Hitachi manufacturers website as you say, and no update driver or firmware is available for the above mentioned drive. It must be that old they don`t even acknowledge it anymore.
