Enabling the power icon on a DESKTOP
slickrcbd
I don't use Vista much anymore since upgrading to Windows 7, but I recently booted into Vista and noticed the power icon was missing. It was greyed out in the "customize notification icons" area.
I tried deleting the keys mentioned here:
System icons do not appear in the notification area in Windows Vista or in Windows 7 until you restart the computer
I also tried methods four then three
http://www.vistax64.com/tutorials/106787-notification-area-system-icons.html
I used to have the power icon available on my desktop computer in Windows Vista 64-bit Home Premium. It was NOT originally available, but I did something to make it available. I can't recall what I did. It's possible that one of the above things worked but that was "fixed" in some Microsoft update.
I'd like to find that third method and see if I can also use it with Windows 7 Professional.
Can somebody please tell me another way to enable that greyed out icon in Vista? I thought I bookmarked the solution, but I can't find the bookmark.
Hello slickrcbd,
Sorry, but the "Power" notification area icon option will remain grayed out unless your computer is a laptop, or a desktop that has a UPS battery backup connected to it.
If you like, the tutorial below can help show you how to create a Power Options shortcut.
How to Create a Power Options Shortcut in Vista
I suppose it may be possible if some 3rd party program added one. By default, a desktop doesn't have the Power/battery notification icon available unless there's a backup UPS connected via it's USB data cable to the desktop computer.
Here's another option below that you could create shortcuts for to pin to the taskbar if you like.
Power Plan - Create Shortcut to Change Power Plan - Windows 7 Forums
