sourceExclusive EVGA GPU Voltage Tuner v.1.0
EVGA now gives you even more ways to maximize your EVGA card, with the exclusive EVGA GPU Voltage Tuner (GVT). This utility allows you to set a custom voltage level for your GTX 295, 280 or 260 graphics card. (see below for full supported list) Using this utility may allow you to increase your clockspeeds beyond what was capable before, and when coupled with the EVGA Precision Overclocking Utility, it is now easier than ever to get the most from your card. With these features and more it is clear why EVGA is the performance leader!
Features:
* Provides an environment to possibly increase your GPU voltage allowing for higher Core/Shader clockspeeds.
* Easy to use interface, with “Apply at Startup” functionality so you do not need to apply on every bootup.
System Requirements:
* Windows XP, Vista and 7. (Both 32/64bit)
* Supported EVGA graphics card (see below)
* Forceware 181.22 or higher drivers
its only able to alter EVGA cards currently, but there will be mods on the way allowing other GT200 vendors to use this S/W.. :D
SKMy Computer
- ME.....
- Q9450 @ 3.6ghz
- P5K PREMIUM
- 8GB 1066mhz buffalo firestix
- HD 5970
- 20'' syncmaster
- 1680x1050
- 160GB 7200RPM SEAGATE BARRACUDA IDE 160GB 7200RPM SEAGATE BARRACUDA SATA 2
- PSU
- XCILIO 850w
- Case
- unknown ATX
- Cooling
- Arctic cooler pro 775
- logitech cordless optical
- logitech EX110
- 2mb
