Solved executable file problem
noocyt
When I try to open any file with the *.exe file, the 'Open With' window is displayed, I suspect I have a virus but can't use my antivirus and cannot use System Restore.
Does anyone have any ideas please?
Cheers noocyt
Make sure you in as Admin if not already. Also if u suspect you have a virus, I would recommend running Malwarebytes or something like it to eliminate that possibility.
    Toshiba Laptop A505 S6965
    Intel Core2 Duo P7350 2.0Ghz
    4Gb DDR2
    ATI Mobility Radeon HD 4570 (512MB)
    16in.
    1366x768
    500gig
    10Mb/896Kb
