I'm running Vista 32 bit and recently I've been having a number of issues that might be unrelated, but I believe they started appearing at about the same time so I suspect there might be some link between them:
- explorer.exe is constantly using exactly 25% CPU
- the left hand side of my start menu is completely empty and no new recently used programs appear there
- when I make changes in the taskbar or start menu properties screens, the taskbar will freeze and I can't click on it anymore
- the cooling fan is behaving erratically, speeding up and slowing down all the time
I thought it might be a virus, but a full scan by Norton showed nothing (it might be something that's not recognised by Norton though, I don't know). My account is the only one having these problems, the rest is unaffected. I assume I could simply make a new account for myself, but I'd rather try to solve the problem first.
When I close down explorer.exe, the CPU and cooling fan go back to normal. I looked at the process with Process Explorer and noticed that there's a lot of changing going on in the processes dependant on explorer.exe: processes are constantly appearing and going away again. This doesn't happen on other user accounts, the processes underneath explorer.exe are constantly the same there.
I've been looking for a solution for a while now, but found nothing that works. I'm not too familiar with the technical aspects of computers so I might be missing something obvious. Anyway, any help would be greatly appreciated.
