Extend volume
andrewbaxter
I'd like to increase the capacity of my C drive which contains the operating system (142GB; 39% free space) by either deleting or shrinking my D drive which is empty (143GB, 100% free space).
I've read several post from users who found that the 'extend volume' option is greyed out and found that this is the case on my laptop.
I have yet to delete or shrink the D drive so there is currently no unassigned space on the disk.
Attached is a screen print of the Computer Management window showing the current situation.
What is my best laid plan?
Regards,
Andrew Baxter.
Have you had a look in the tutorial part of the site to see if there is anything there that can help?
My thoughts would be that you would have to go into the D partition and delete it which would put it as unallocated space, then you should be able to extend the C partition into that space.
Hopefully the experts will see this post and give you all the information you need and say if I got it right or wrong ;)
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
Hello Andrew, and welcome to Vista Forums.
Unfortuntately you will not be able to do this using Disk Management, but you should be able to using a free program like Partition Wizard.
