External Drive problems
makion91
Hi guys,
The problems I've been having is with my Windows Vista Home Premium 32bit, Toshiba Laptop (A300).
For some reason, It's unable to either normally format any external memory devices into a FAT or FAT32 format, or unable to read it at all. I keep trying to open the device but it keeps saying that i need to format it, but because of problem 1, it can't be formated (it almost completes but the process shuts down, stating that it can't be formated)
This problem has been happening for the longest time and I really need this fixed.
When I say external memory devices, i mean CDs, DVDs, Flash drives, SD cards, memory card readers. Everytime I check the disk management of these devices, it says they are Primary Partitioned (which is the normal status right?). And the only thing that seems to be the problem is the RAW file system (which I heard windows doesn't read)
However, the wierd thing is if I plug in something like a USB mouse, or a camera, it has full functionality (I.E. the mouse works/files are reachable on the camera).
I then tried to format it using the cmd lines, and tried to format it to FAT32, but after it says 100% formated, and i try to use it again, Disk Management tells me that it's back in RAW format.
How can i fix this...
Thank you in advance.
Try this: in disk management, right click on the left pane (where it say disk0, disk1, etc.) and initialize. Then try to format.
    Dell
    Q6600
    HP w2207h
it doesnt give me the option of initialize :(
it only gives me..."Change Letter and Paths", "Eject", "Properties", and "Help"
When i click on properties, it actually says my device is working perfectly fine too.
Hmm, then I am out of ideas. Sorry.
    Dell
    Q6600
    HP w2207h
On Sat, 24 Apr 2010 22:01:14 -0500, makion91 <[email protected]>
>"Help"
>perfectly fine too.
What happens if you format it on another computer, then bring it to
the Vista machine to read?
That would work. But the if other computer is Vista too, you'll run into the same problems. But a Linux system may work, just make sure you format into NTFS.
    Dell
    Q6600
    HP w2207h
On Fri, 30 Apr 2010 00:39:50 -0500, whs <[email protected]>
>format into NTFS.
My thought was to do it as a diagnostic tool, to determine if the
problem is with Vista or with his memory stick.
>format into NTFS.
Yes , there may be problem with the memory stick.
Please let us know what message do you get when u perform the same operation with other machine
