Hiya,
I'm having a very strange problem with my External Hard Drives (I have 2). What happens is that I am unable to open either of the external Hard Drives in 'Computer' by double clicking them. It just doesn't do anything. But when I right click and select 'Open' it says:
"Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item."
EDIT: Forgot to mention that I have checked the security details for the drives and I should be able to access them just fine.
But here is where it gets weird. I can right click and select 'Explore' and it will open up like normal and I can browse the folders just fine!
I used to be able to access these Hard Drives just fine before, but then they just went like this and I have no idea why. Since it happened to both Hard Drives simultaneously, I figure it is a Vista problem and not related to the specific drives.
Other symptoms are that the icon for the drives no longer shows up in 'Computer', although the name and disk space turn up fine. Also, I've noticed that the drives are operating much slower than usual, nearly a tenth of the normal read/write speed.
OS Name Microsoft® Windows Vista™ Home Premium
Version 6.0.6001 Service Pack 1 Build 6001
Thanks,
Thanks,
