Solved Extraction Fan?
xTweakx
I was told I need an "extraction fan" for a video card I wanna get. Is that just the fan you can put over the vent on the back of your computer from the inside?
    Acer Aspire T180
    AMD Athlon 64 3500+ 2.20GHz
    3.00GB
    e-GeForce 8500 GT
    1024 x 768
    160GB Stock 250GB External
    Wireless
    Wireless
    Upgrading video card, fan. Maybe sound card, dual monitors, and speaker system.
I believe that is what he meant since he thinks your video card will cook up lot of heat and you need a fan at the back to "extract" the heat.:D
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Hello xTweakx,
Usually this would just be a rear case fan. I would get one that has the highest CFM (cubic feet per minute) and lowest noise (db) level you can find for the best airflow.
Alright cool. I have a rear fan from another computer of mine, but I think it was stock so it might not be good enough. Anyway, is there a way I can check the cubic stuff and the noise level?
    Acer Aspire T180
    3.00GB
    e-GeForce 8500 GT
    1024 x 768
    Wireless
    Wireless
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Alright, thanks. I'm glad they aren't much money.
    Acer Aspire T180
    3.00GB
    e-GeForce 8500 GT
    1024 x 768
    Wireless
    Wireless
    Acer Aspire T180
    3.00GB
    e-GeForce 8500 GT
    1024 x 768
    Wireless
    Wireless
xTweakx, I can't find much about this fan. However case fans are not expensive. I always prefer 120mm. Zalman make a good fan a bit noisy though, as do Noctua who make a silent fan series which cost a bit more ($19AUD). You need to go for a good quality fan. Best to avoid E-Bay, unless it is an established brand. What existing cooling do you have ie how many fans, what size etc.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
By the way, The SilenX fan suggested by BruceX is a particularly good fan with really good noise characteristics. I have 3 120mm Noctua fans in my stock system.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Well after I get the HD 4850, I will have the one that is on the video card, the one that is on my motherboard and then I would have the one I showed you if I took it off my other computer. Would that get me by?
    Acer Aspire T180
    3.00GB
    e-GeForce 8500 GT
    1024 x 768
    Wireless
    Wireless
If you are running everything at stock that should be heaps. You can keep an eye on temperatures using a variety of programs you can download. These use the info provided by the motherboard. I have an Asus and use the Asus PC Probe II.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
I would say that would be fine as long as your not overclocking anything. Once you have the HD 4850 with a fan of it's own, the fan you have now will be just pure extra cooling.
EDIT: I got it working, most of the temps changed, one stayed the same. Alot of them jump from temp to temp by 2 or 3c. Sounds right though.
    Acer Aspire T180
    3.00GB
    e-GeForce 8500 GT
    1024 x 768
    Wireless
    Wireless
xTweakx,
You may not have is connected to a system fan plug pins on the motherboard. It may be labeled something like SYS_FAN, SYS_FAN1, etc.. on the board.
You may also check your BIOS settings to see if there is some option to only turn on the system fans as needed. If you do, just set them to always on.
first look at the holes in your case and find out what size fan your case will accept.
    E8400
    asus p5ql-e
    ocz pc 1066 2x2gb
    asus eah3650 silent
    Edirol UA-25
    Gateway FPD2185W
    1680 x 1050
    750g samsung
    Zalman ZM460B 460W
    Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
    Coolermaster Hyper Z600 fanless CPU cooler
    Microsoft Laser Mouse 6000
    Merc Stealth
    DSL
xTweakx,
I'm happy to hear that you got it sorted out. Thank you for posting back your results.
Well it fit/screwed in perfect on the computer. And the temps have actually all dropped about 3-5c. Most 4c. So it's running how it should now. At least it's something until I get out and get a good fan. Thanks guys..
    Acer Aspire T180
    3.00GB
    e-GeForce 8500 GT
    1024 x 768
    Wireless
    Wireless
