Fan problem?
eknirb
I mentioned this a couple of weeks ago. PC boots up, loads fine. Moments later, LOUD whirring noise. Lasts for maybe 60 seconds, dies off. That was two weeks or so ago.
This morning, get it again. Same characteristics. Fan issue? Seems to be running warm @ the core, doesn't it? I've seen it as low as 44.
    HP m8200n Windows Media Center
    AMD Athlon 64x2 Dual Core Processor 6000+ 3.00GHz
    3.00 GB
    HP widescreen w1907
I rebooted, and now core says "48"...now down to "38."
Hmmm.
    3.00 GB
    HP widescreen w1907
40 or lower at idle would be good. You see to be running a bit above that. Does sound like a fan problem.
now @ 42. What would cause it to jump like that and go back down, 2 weeks apart?
    3.00 GB
    HP widescreen w1907
It sounds like the fan is going. When working properly temp is ok, when not running properly the temp increases.
My brother picked up a computer that had that problem, he simply took the fan top off, put some grease where it spins, and put it back together and it's fine.
    eMachines ET 1161-05
    AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
    3gb
    Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
    Realtek HD Audio
    Samsung 23" LED, 1920 x 1080 resolution
    1920x1080
    160gb Seagate
    Cool Master Extreme Power Plus - 500watts
    APEVIA X-Trooper Case w/ Side Window-Blue
    4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
    Logitech k800 Wireless Illuminated Keyboard
    150mbps
    Linksys WUSB100 Insignia 2:1 Sound system.
