Solved favorites folder and import problems
PETERPNYC:
A toast! :party:
Here's hoping you will always enjoy your adventures in Windows Vista.
Best Wishes.
Ardneh
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
Well I looked back at the original post
http://www.vistax64.com/vista-gener...ocuments-folder-how-do-i-delete-one-them.html
and tried deleting one item from my c\user\PetrP\favs folder and it was also deleted from my explore\desktop\Peter P Green iconed favs folder with the star on it .
I also deleted one item from my C\User\PeterP \downloads favs folder and the same item was deleted from my Explore \Desktop\PeterP downloads favs folder. So we have estabilished that these two folders are identical and linked in different places.
Having fun yet.
Now the question is can I delete the entire Downloads \favs folder in either place and just leave the remaining Green Iconed favs folder with the star on it in both places?? Dangerous to try ??
    DELL VOSTRO 1500
    INTEL DUO CORE DUO 1.4
Dangerous to try ??
I don't know.
But I bet you're going to.:D
Ardneh
    Compaq/SR5130NX
I suspect that they are the same folder, but approached through different paths.
You can walk in the front door or the back door of your house, it's still just one house.
Ardneh
    Compaq/SR5130NX
Ardneh
But they do not have th exact same info in them . The 2 different download folders might be one house and the plain favs folders be another?
If I delete the one in downloads will I lose the one in Green iconed Favs ? Should I try ??
    DELL VOSTRO 1500
Clearly I've misunderstood the situation.
Please refer to my previous post that begins:
Dangerous to try ??:)
Best of Luck.
Ardneh
    Compaq/SR5130NX
Before you do, make a backup copy of the folder's content to make it easy to restore later if needed.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
I did it before I saw your post . Everything seems to be Ok and now I only have 2 folders Favs Green icons in C and desktop Peter P .No more in documents or downloads.
How do I make a correct backup onto a flash drive. It was trying to import from a flash drive that I used export on my XP machine that started all this trouble > I got an invalid format file or something error.
Whats the best way to send to a hard drive Export directly out of IE 7 ?
    DELL VOSTRO 1500
Peter,
I would just use Copy and Paste on the C:\Users\(user-name)\Favorites folder itself to back it up. If you need to restore it, you can then just copy the contents of the folder back into the C:\Users\(user-name)\Favorites folder on the computer.
Peter,
I COPIED AND PASTED TO MY DESKTOP. sorry caps
I also exported to my flash drive via IE . Thx for all
Peter P
    DELL VOSTRO 1500
You're most welcome Peter. :)
Peter, just in case you are reading this, don't feel bad about all the questions.
I have, unfortunately used Vista for over a year and a half. Seldom used IE but Favorites were ok. Then, somehow IE 8 appeared on my computer even though I'd hidden it as an update. I uninstalled the update but my Favorites were everywhere, all messed up, and even my Bookmarks in Firefox were off. Trying to import from Firefox or sync via IE Pro only put duplicates of each link in the various duplicate folders.
This thread has helped me with all my duplicate folder!
This thread helped me immensly also. And I have me preferences set to receive emails for all replys to this thread so I stay in touch with all new info:)
    DELL VOSTRO 1500
