You should upgrade or use an
alternative browser .
File stuck in print queue solution broke Vista
Hi. I tried the solution in
post 6 of
this thread . It successfully removed the document stuck in my printer's queue. However, upon restarting Windows I get the following messages:
Window Title : Run DLL
Message : Error loading C:|Windows\system32\NvCpl.dll. Specified module not found
Window Title : .NET
Message : Runtime optimization service stopped working and was closed.
I tried to restore my old system, but apparently System Restore was turned off (aside: how the heck did that happen?).
Edit : I also looked for NvCpl.dll in my Recycle Bin, but it's not there.
Edit : I have an SSD, so cannot use a file recovery program.
Any advice on how to fix? Is my system broken or can I at least keep working until NvCpl is fixed?
TY.
тσωηsвg
It looks like that file is part of the nvidia drivers so please try to uninstall and reinstall your graphic drivers.
Operating System
Windows 7 Pro & 10 Pro
HP Pavillion Elite HPE-250f
8 gb
ATI Radeon HD 5770 1 gb ram
Alienware 25 AW2521HF
1920x1080 &1680x1050
1 TB & 500 GB
Thanks. That fixed the NvCpl.dll error.
I still have the .NET error.
тσωηsвg
More than likely you don't need that service and can disable it if you want to.
Operating System
8 gb
1 TB & 500 GB
How do I do that? I looked in Services, but do not find anything called 'Runtime Optimization' service.
тσωηsвg
I think it might be ASP.net runtime optimization service. You might also try under msconfig.
Operating System
8 gb
1 TB & 500 GB
