Firefox problems.
pjjppj
Firefox when restarted signs out of all websites. It is nothing to do with the cookies in firefox its self.
It also wont save passwords for certain sites. And when it does, it doesnt automatically put them in or let me select them from a dropdown menu. However it saves some passwords. Any help?
    Mobile DualCore Intel Core 2 Duo T7100, 1800 MHz (9 x 200)
    Sony VGN-FZ18L Intel Crestline-PM PM965
    1GB DDR2 SDRAM
    NVIDIA GeForce 8400M GT (64 MB)
    SigmaTel STAC9872AK @ Intel 82801HBM ICH8M - High Definition
    TOSHIBA MK1637GSX (160 GB, 5400 RPM, SATA-II)
    Alps Pointing-device for VAIO
    20MB Virgin Media
Thanks I will look:)
    1GB DDR2 SDRAM
    20MB Virgin Media
I agree with Mark5019 about checking mozillaZine. Firefox signs out of all websites when terminated / restarted for security reasons. Also, the passwords it collects will only be associated to the form (or some similar object...can't remember exactly) that they were saved with. So if there are several different places to log into your favorite site, there's a strong chance that you will have to have firefox remember your password on each of them. It should, however, allow you to sign into the same UN/PW box on a website without a problem, unless the website itself is messing with this feature. Hope this helps a bit.
    N/A
    Intel Q6600
    abit IP35 Pro
    8GB Corsair
    GeForce 9800 GX2
    Built-in
    Vison 18" Widescreen (generic)
    1440 x 900 native
    RAID 1: Two WD 640 GB drives
    Drawing a blank...1000+ watts
    Thermaltake Armor
    A lot of fans
    Generic optical mouse from ZT systems
    Logitech G15
    Cable (actual speed varies)
