flash player
calmat
maps.JPGhi everyone
I have just downloaded and installed the latest version of flash player, the problem
is that it keeps telling me that i need the new version of flash player to run
some of my programmes even though i have the new version installed. (see attached)
can anyone please help.
regards calmat
Cal,
Just and educated guess based on experience. I think that you have remnants of the older version. Uninstall with revo uninstaller (I think that we used it before). Then install the new version. Boot after uninstall.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
hi everyone
I have tried both uninstalls, and then installed the new version of flash player
but i am still getting the same problem, is their any other remedies.
regards calmat
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
hi everyone
thanks to everyone for your help and advice. I have solved my problem, I opened up my manage- add -ons and I noticed that shockwave flash object was disabled.
I enabled it and this has resolved the problem.
I hope this has helped anyone who has had same problem as me.
regards calmat
Thanks for sharing your solution. Perhaps it will help someone else someday. :)
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
