format hard drive
nabsky
I have vista Home on a preloaded Dell PC which is now infected with virus which crashes each time I try to load anything like virus protection. Also the PC runs slowly, so what I want to do is to format and start a fresh. However I dont have the vista disks so I will load an old copy of xp for my old PC. Which really may be a relief. My question is how can I format without the help of a startup disk?
Hello Nabsky,
You can pick up at STEP 3 at the link below to do a Dell factory restore. It will format the partition that Vista is on as part of reinstalling Vista back like it was the day you first got it from the recovery partition.
Dell - Technical Support
    S-Vaio FZ
    Intel Core2duo T7100-1.8GHz
    DDR2-2GB-PC2.5300-Sp.667MHz
    Mobile Intel Graphics Media Accelerator X3100-358MBvideo ram
    200GB/7200Rpm/Serial ATA
