Blackhawk7188
I have a Dell D500 with the Intel Pentium M @ 1.3 GHz. Lately my pc has been acting slow and I ran CPU-Z to check the clock and it said that it is running at 598.6 MHz. I was wondering why? I when into the BIOS and it is set at 1.3 Ghz as the CPU speed, but the SpeedStep is turned on. Is speedstep causing this to happen? If so, other than turning it off in the BIOS, which it wont let me allow, is there any way of overriding this. Right now it has Windows XP Home SP3 installed with 768 DDR RAM. I am using the "Always on" config in the power options btw.
I tried to update the BIOS but it wont let me since my battery is dead and wont says its not connected for some reason. Even if conncected to the AC outlet doesnt seem to matter.
Thanks in advance for your help.
- HP Pavilion DV7-1129wm Entertainment PC
- AMD Turion X2 RM-72 Dual Core @ 2.1GHz
- 2 x 2 GB Hyundai DDR2 400 MHZ
- ATI Mobility Radeon HD 3200 @ 256 MB
- IDT High Definition Audio/SRS Premium Sound/Altec Lansing
- 17" Laptop Screen
- 1440 x 900 laptop, external 17 in LCD 1024 x 768
- WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
- PSU
- 8 Cell Lithium Ion Battery
- Case
- Laptop with "light up" HP Logo on outside
- Cooling
- Insane air coming out of Targus dual fan cooler
- Microsoft Wireless Mobile Mouse 3000 / Touchpad
- Full Keyboard with numpad
- Comcast Cable 20 MBps
- Other Info
- Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
