Gears Of War Problem :[
eLaD
Ok I Can Run GOW In Requirements Setings But when i try to run it is Make This Problem :
You Cannot Run This Game With ModiFied Plese Reinstal The Game"
What Should I Do????????????????????
PLZZZ HALP
Thankes.
*I Download This Game Don't Buy It.
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Its for gears of war 1 ;)
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Just run the installer and it will find where you installed gears automatically.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Download the latest games for windows live, from in game.
Here is the latest patch.
(It's scanned and clean.)
You will have to apply a no cd patch to make it work, after patching.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
When I'm open it is write to me :
"old file not found. However,A file of the same name was found. No Update done since file contents do not match."
What to do?/?/?/?/?/?
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
This startup will allow you to play the game with no cd, use it.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I Now, i have startup I'm dont srupid,
but when i try to start the game it's make this problem : "You Cannot Run This Game With ModiFied Plese Reinstal The Game"
THAT'S WHAT I TALK ABOUT 2 PAGES :]: I DONT NEED STARTUP :]
Ok, success, you will have to follow these instructions and the game will play ok.
1. Clean install. (Delete the Gears of War folder in Microsoft Games Folder after un-installing the game).
2. Install game.
3. Apply this patch.
4. Start game and update Windows Live from inside the game. (You will need an account to play which is free).
5. If you have game crashes, you will have to use the No Cd patch, but only if you have issues.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Looolllllll i do it I Can playy Gearsssssssssssssssssssssssssssss
I Just need to Change My Computer Date to 2007 and play
But Thanks you all for trying to halp me really Thanks you :]]]]]
