When posting a query about something not working correctly in Vista, please remember to enclose as much detail about your system as possible, even if it doesn't seem relevant. This includes any USB/Firewall devices whether they be external or internal. A lot of problems can be remedied by going to the hardware manufacturer and installing an update for a problematic device. If your system was working correctly before you installed an application or update, then please state which. Finally, if you are not sure where to post your query, please post it in the 'General Discussion' area of the forums. The Administrators/Moderators will move it to a more suitable area if necessary.
When posting, DO NOT give your topic a title of:
BE SPECIFIC in choosing a title for your post. It can help us better help you.
Give the people helping you total respect. They help you for FREE!
This is an ENGLISH only Forum. You can find online translators on the web to translate your message for you.
Help us help you. When you post, post as much information as you can.
Dwarf
- - HELP ME PLEASE!
- I NEED HELP!
- I have a question.
- BIG problem!
- NOOB needs help!
- Problems
- URGENT!
- HELP ME PLEASE.
- - Your Setup i.e. CPU, motherboard, graphics card, memory
- Your version of Vista and if it's 32 or 64 bit
- Your specific problem
- Be as detailed as possible
Dwarf
- Dwarf Dwf/11/2012 r09/2013
- Intel Core-i5-3570K 4-core @ 3.4GHz (Ivy Bridge) (OC 4.2GHz)
- ASRock Z77 Extreme4-M
- 4 x 4GB DDR3-1600 Corsair Vengeance CMZ8GX3M2A1600C9B (16GB)
- MSI GeForce GTX770 Gaming OC 2GB
- Realtek High Definition on board solution (ALC 898)
- ViewSonic VA1912w Widescreen
- 1440x900
- OCZ Agility 3 120GB SATA III x2 (RAID 0) Samsung HD501LJ 500GB SATA II x2 Hitachi HDS721010CLA332 1TB SATA II Iomega 1.5TB Ext USB 2.0 WD 2.0TB Ext USB 3.0
- PSU
- XFX Pro Series 850W Semi-Modular
- Case
- Gigabyte IF233
- Cooling
- 1 x 120mm Front Inlet 1 x 120mm Rear Exhaust
- Microsoft Comfort Mouse 3000 for Business (USB)
- Microsoft Comfort Curve Keyboard 3000 (USB)
- NetGear DG834Gv3 ADSL Modem/Router (Ethernet) ~4.0 Mb/s (O2)
- Other Info
- Optical Drive: HL-DT-ST BD-RE BH10LS30 SATA Bluray Lexmark S305 Printer/Scanner/Copier (USB) WEI Score: 8.1/8.1/8.5/8.5/8.25 Asus Eee PC 1011PX Netbook (Windows 7 x86 Starter)
