Solved General Suggestion...
PainlessTorture
Official Best Member
Vista Pro
Hey guys. I just thought i would post a tip here...
I recently seen a virus which encrypted itself for protection. It took forever to get rid of and i thought it was very smart.
So the following commands will prevent a virus from encrypting itself (hopefully).
1) takeown /f "c:\windows\system32\cipher.exe" (/a)
Putting the /a at the end will give ownership to the Administrator group. Without the /a it will be given to the user who executed the command.
icacls "c:\windows\system32\cipher.exe" /deny everyone:f
As far as i know this should work. It will also prevent a user from encrypting files via a command line and possibly via a GUI too. Im not sure. However if you do not use the EFS i suggest you do this. If you do use it, i suggest renaming the command to something less obvious.
The cipher command is only on advanced versions of XP and Vista. It will not be on home versions.
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
Your method is fine. It's good to have a few alternatives. :)
