general
how do i find a post i put on at a later date and how do i delete post and does post automaticly delete after time, do not understand forums completely and trying to understand how to use
http://www.vistax64.com/vista-news/229025-vista-sp2-out.html
You want this one?
Or the DLL
Posts do not delete. You must use the edit and then delete button at the bottom of the posting screen
If you want to find a post in current use, just go to user cp, then you will see any answers to your posts. You can go to subscribed thereads to find any of your posts from Users Control Panel
Press edit, then delete
I think that if you are the first poster (guy with the question) you cannot delete.
That was very nice of you. All members should be so concerned. We like to keep the posts, however. This forum is used by many to come and research their own problems. If you keep your posts with problems, you are helping others.
