ok, lets see if i can say wht im thinking
i currently have a ATI RADEON HD 4650, graphics card in my laptop.
i have run the most resourse hugging games for hours and heat hasnt yet been reli an issue.
if i wanted to upgrade to say a 4800 series card, could i just switch them over and instal new drivers?
or do u think it will cause it to over heat being a laptop?
and will the output of these cards be too much for my system to handle, therefor limiting the amount of data they can proces, therefor no point in me getting it?
i have a brand new dv7t pavilion.
if you need any more information or clarification of my question just ask.
thanks!
thanks!
- HP DV7T PAVILION
- dual 2.66GHz
- Quanta 3624
- 4GB DDR2
- ATI RADEON HD 4650
- 17.3" HD
- 500GB 7200RPM SATA
 It's probably around the 3K mark with all the bits and pieces.  That's also in Australian dollars which is why it cost so much
