Graphic Card not working.
WeKing
i just built my new computer, but when i turn it on my monitor say "No signal detected." My monitor is a 21" BenQ.
Gigabyte GA-X58A-UD7, X58
Western Digital Caviar SE16 500GB SATA2
Corsair Dominator DDR3 1600MHz 4GB CL8 (Delivered back, and bougth Corsair Dominator DHX+ DDR3 1600MHz 6GB instead but haven't recieved them yet.)
Intel Core? i7 Quad Processor i7-930
XFX Radeon HD 5770 1GB GDDR5
Cooler Master CM 690 II Advanced Sort
Corsair TX 950W PSU
That's my specs. Dont know what to do know :S
I'm going to "assume" that you've already done this, but....
The last one I built, I had to take the video card out and re-seat it in the slot. I know it sounds kinda pointless, but it worked for me. Not sure why it worked though. My guess is the stiffness of the pins in the slot, but who knows.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    Creative X-FI Xtreme Gamer
    AOC 22" Widescreen
    320GB
    2 front, 2 back,one side
    Logitech Wireless LX310
    Logitech Wireless
    18/2 cable
Does the machine beep when it's POSTing? (if you have a mobo speaker attached)
Have you tried booting with the card in another slot?
Triple checked that the PCI-e power plugs are firmly secured, or even tried swapping plugs?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
you Mobo has an On-board Debug LED display for troubleshooting
what code is it displaying?
If you kept the Mobo Manuel you should be able to reference the code somewhere in the code index most likely at the back of the manual
If like my Abit board it should refance like
0.0 - operational - ready for operation (standby mode)
F.F - Fully functional (all checks OK)
0.1 - boot procedure and so on
Sometimes this system can be had to understand but we are here to help you with that provided you can give us as much info from the reference guide as possible
Edit: did you connect the supplementary dins to the (GPU) Graphics card?
Manual found here http://download.gigabyte.eu/FileList/Manual/mb_manual_ga-p55a-ud7_e.pdf
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
check to make sure that the gpu is seated in the correct slot,and that the pcie cable fromt he psu is properly connected, and also make sure your vga/dvi cables are plugged in correctly.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
it does stand 8.8. on the motherboard while they are some different lights.
Green, yellow, green, yellow right over the power supply to the mainboard.
at the bottom to right there is some other lights.
Green, green, yellow, yellow, red, red.
I think that is 8.B rather than 8.8 in which case its meaning is:
8Bh 1. Invoke all ISA adapter ROMs
2. Invoke all PCI ROMs (except VGA)
This to me doesn't mean much but im sure someone else here will know, just bare with us
My opinion of it is that there is a fault with the graphics card since ABIT(hex) lists: 8.B. AGP voltage ready
or
8B
and when you compare the 2 hex lists the are almost identical
you can also try a C'mos reset
Gigabyte Hex: POST Error Code
Code:
5-4 POST Error Code
POST (hex) Description
CFh Test CMOS R/W functionality
C0h Early chipset initialization:
-Disable shadow RAM
- Program basic chipset registers
C1h Detect memory
- Auto-detection of DRAM size, type and ECC
C3h Expand compressed BIOS code to DRAM
C5h Call chipset hook to copy BIOS back to E000 & F000 shadow RAM
01h Expand the Xgroup codes locating in physical address 1000:0
02h DualBIOS init (optional)
03h Initial Superio_Early_Init switch
05h 1. Blank out screen
2. Clear CMOS error flag
07h 1. Clear 8042 interface
2. Initialize 8042 self-test
08h 1. Test special keyboard controller for Winbond 977 series Super I/O chips
2. Enable keyboard interface
0Ah 1. Disable PS/2 mouse interface (optional)
2. Auto detect ports for keyboard & mouse followed by a port & interface swap (op- tional)
3. Reset keyboard Super I/O chips
0Eh Test F000h segment shadow to see whether it is R/W-able or not. If test fails, keep beeping the speaker
10h Auto detect flash type to load appropriate flash R/W codes into the run time area in F000 for ESCD & DMI support
12h Use walking 1's algorithm to check out interface in CMOS circuitry. Also set real-time clock power status, and then check for override
14h Program chipset default values into chipset. Chipset default values are MODBINable by OEM customers
16h Initial onboard clock generator if Early_Init_Onboard_Generator is defined. See also POST 26h
18h Detect CPU information including brand, SMI type and CPU level
1Bh Initial interrupts vector table. If no special specified, all H/W interrupts are directed to SPURIOUS_INT_HDLR & S/W interrupts to SPURIOUS_soft_HDLR
1Dh Initial EARLY_PM_INIT switch
23h 1. Check validity of RTC value:
e.g. a value of 5Ah is an invalid value for RTC minute
2. Load CMOS settings into BIOS stack. If CMOS checksum fails, use default value instead
- 133 - Appendix
24h Prepare BIOS resource map for PCI & PnP use. If ESCD is valid, take into consider- ation of the ESCD's legacy information
25h Early PCI initialization:
- Enumerate PCI bus number
- Assign memory & I/O resource
- Search for a valid VGA device & VGA BIOS, and put it into C000:0
26h 1. If Early_Init_Onboard_Generator is not defined Onboard clock generator initializa- tion. Disable respective clock resource to empty PCI & DIMM slots
2. Init onboard PWM
3. Init onboard H/W monitor devices
27h Initialize INT 09 buffer
29h 1. Program CPU internal MTRR for 0-640K memory address
2. Initialize the APIC for Pentium class CPU
3. Program early chipset according to CMOS setup Example: onboard IDE controller
4. Measure CPU speed
2Bh Invoke video BIOS
2Dh 1. Initialize double-byte language font (optional)
2. Put information on screen display, including Award title, CPU type, CPU speed, full screen logo
33h Reset keyboard if Early_Reset_KB is defined e.g. Winbond 977 series Super I/O chips. See also POST 63h
35h Test DMA Channel 0
37h Test DMA Channel 1
39h Test DMA page registers
3Ch Test 8254
3Eh Test 8259 interrupt mask bits for channel 1
40h Test 8259 interrupt mask bits for channel 2
43h Test 8259 functionality
47h Initialize EISA slot
49h 1. Calculate total memory by testing the last double word of each 64K page
2. Program write allocation
4Eh 1. Program MTRR of M1 CPU
2. Initialize L2 cache for P6 class CPU & program CPU with proper cacheable range
3. Initialize the APIC for P6 class CPU
4. On MP platform, adjust the cacheable range to smaller one in case the cacheable ranges between each CPU are not identical
50h Initialize USB Keyboard & Mouse
52h Test all memory (clear all extended memory to 0)
53h Clear password according to H/W jumper (optional)
55h Display number of processors (multi-processor platform)
57h 1. Display PnP logo
2. Early ISA PnP initialization
- Assign CSN to every ISA PnP device
Appendix - 134 -
59h Initialize the combined Trend Anti-Virus code
5Dh 1. Initialize Init_Onboard_Super_IO
2. Initialize Init_Onbaord_AUDIO
60h Okay to enter Setup utility; i.e. not until this POST stage can users enter the CMOS setup utility
63h Reset keyboard is Early_Reset_KB is not defined
65h Initialize PS/2 Mouse
67h Prepare memory size information for function call: INT 15h ax=E820h
69h Turn on L2 cache
6Bh Program chipset registers according to items described in Setup & Auto-configura- tion table
6Dh 1. Assign resources to all ISA PnP devices
2. Auto assign ports to onboard COM ports if the corresponding item in Setup is set to "AUTO"
6Fh 1. Initialize floppy controller
2. Set up floppy related fields in 40:hardware
75h Detect & install all IDE devices: HDD, LS120, ZIP, CDROM...
77h Detect serial ports & parallel ports
7Ah Detect & install co-processor
7Ch Init HDD write protect
7Fh 1. Switch back to text mode if full screen logo is supported
- If errors occur, report errors & wait for keys
- If no errors occur or F1 key is pressed to continue:
2. Clear EPA or customization logo
82h 1. Call chipset power management hook
2. Recover the text fond used by EPA logo (not for full screen logo)
3. If password is set, ask for password
83h Save all data in stack back to CMOS
84h Initialize ISA PnP boot devices
85h 1. USB final Initialization
2. Switch screen back to text mode
87h NET PC: Build SYSID structure
89h 1. Assign IRQs to PCI devices
2. Set up ACPI table at top of the memory
8Dh 1. Enable/Disable Parity Check according to CMOS setup
2. APM initialization
8Fh Clear noise of IRQs
93h Read HDD boot sector information for Trend Anti-Virus code
- 135 - Appendix
94h 1. Enable L2 cache
2. Program daylight saving
3. Program boot up speed
4. Chipset final initialization
5. Power management final initialization
6. Clear screen & display summary table
7. Boot BIOS support (popup menu)
95h Update keyboard LED & typematic rate
96h 1. Build MP table
2. Initialize power-saving (optional)
3. Set CMOS century to 20h or 19h
4. Load CMOS time into DOS timer tick
5. Build MSIRQ routing table
FFh Boot attempt (INT 19h)
Abit Hex: POST Error Code
Code:
A-1
Appendix A. POST Code Definition
AWARD POST Code Definition:
POST
(hex) Description
CF Test CMOS R/W functionality
C0
-Disable shadow RAM
-Disable L2 cache (socket 7 or below)
-Program basic chipset registers
C1
Detect memory
-Auto-detection of DRAM size, type and ECC
-Auto-detection of L2 cache (socket 7 or below)
C3 Expand compressed BIOS code to DRAM
C5 Call chipset hook to copy BIOS back to E000 & F000 shadow RAM
01 Expand the Xgroup codes locating in physical address 1000:0
03 Initial Superio_Early_Init switch
05
1. Blank out screen
07
08
0A
2. Auto detect ports for keyboard & mouse followed by a port  & interface swap (optional)
3. Reset keyboard for Winbond 977 series Super I/O chips
0E Test F000h segment shadow to see whether it is R/W -able or not.  If test fails, keep
beeping the speaker
10 Auto detect flash type to load appropriate flash R/W codes into  the run time area in F000
12 Use walking 1’s algorithm to check out interface in CMOS  circuitry. Also set real-time
14 Program chipset default values into chipset. Chipset default  values are MODBINable by
OEM customers
16 Initial onboard clock generator if Early_Init_Onboard_Generator  is defined. See also
POST 26.
18 Detect CPU information including brand, SMI type (Cyrix or Intel)  and CPU level (586
or 686)
1B Initial interrupts vector table. If no special specified, all H/W  interrupts are directed to
SPURIOUS_INT_HDLR & S/W interrupts to SPURIOUS_soft_HDLR.
1D Initial EARLY_PM_INIT switch
1F Load keyboard matrix (notebook platform)
A-2
21 HPM initialization (notebook platform)
23
1. Check validity of RTC value: e.g. a value of 5Ah is an invalid  value for RTC minute.
instead.
24 Prepare BIOS resource map for PCI & PnP use. If ESCD is  valid, take into consideration
of the ESCD’s legacy information.
25
Early PCI Initialization:
-Enumerate PCI bus number.
-Assign memory & I/O resource
-Search for a valid VGA device & VGA BIOS, and put it into  C000:0
26
1. If Early_Init_Onboard_Generator is not defined Onboard clock  generator initialization.
Disable respective clock resource to empty PCI & DIMM slots.
2. Init onboard PWM
27 Initialize INT 09 buffer
29
1. Program CPU internal MTRR (P6 & PII) for 0-640K memory  address.
2. Initialize the APIC for Pentium class CPU.
3. Program early chipset according to CMOS setup. Example: onboard  IDE controller.
4. Measure CPU speed.
2B Invoke Video BIOS
2D
1. Initialize double-byte language font (Optional)
screen logo.
33 Reset keyboard if Early_Reset_KB is defined e.g. Winbond 977  series Super I/O chips.
See also POST 63.
35 Test DMA Channel 0
37 Test DMA Channel 1.
39 Test DMA page registers.
3C Test 8254
3E Test 8259 interrupt mask bits for channel 1
40 Test 8259 interrupt mask bits for channel 2
43 Test 8259 functionality
47 Initialize EISA slot
49
2. Program writes allocation for AMD K5 CPU
4E
50 Initialize USB
52 Test all memory (clear all extended memory to 0)
53 Clear password according to H/W jumper (Optional)
55 Display number of processors (multi-processor platform)
A-3
57
Display PnP logo
-Assign CSN to every ISA PnP device
59 Initialize the combined Trend Anti-Virus code
5B (Optional Feature) Show message for entering AWDFLASH.EXE from  FDD (optional)
5D
60 Okay to enter Setup utility; i.e. not until this POST stage can  users enter the CMOS setup
utility
63 Reset keyboard if Early_Reset_KB is not defined
65 Initialize PS/2 Mouse
67 Prepare memory size information for function call: INT 15h  ax=E820h
69 Turn on L2 cache
6B Program chipset registers according to items described in Setup  & Auto-configuration
table
6D
“AUTO”
6F
75 Detect & install all IDE devices: HDD, LS120, ZIP, CDROM …
76
(Optional Feature)
Enter AWDFLASH.EXE if:
-AWDFLASH is found in floppy drive
-ALT+F2 is pressed
77 Detect serial ports & parallel ports.
7A Detect & install co-processor
7C Init HDD write protect
7F
-If errors occur, report errors & wait for keys
-If no errors occur or F1 key is pressed to continue: Clear EPA or  customization logo
E8POST.ASM starts
82
2. Recover the text font used by EPA logo (not for full screen logo)
83 Save all data in stack back to CMOS
84 Initialize ISA PnP boot devices
85
87 NET PC: Build SYSID Structure
89
2. Set up ACPI table at top of the memory.
A-4
8B
8D
2. APM Initialization
8F Clear noise of IRQs
93 Read HDD boot sector information for Trend Anti-Virus code
94
1. Enable L2 cache
2. Program Daylight Saving
4. Chipset final initialization.
7. Program K6 write allocation
8. Program P6 class write combining
95 Update keyboard LED & typematic rate
96
1. Build MP table
2. Build & update ESCD
FF Boot attempt (INT 19h)
A-5
AC2003 POST Code Definition:
POST
(hex)
Description
Power On Sequence
8.1. Start power on sequence
8.2. Enable ATX power supply
8.3. ATX power supply ready
8.4. DDR voltage ready
8.5. Setup PWM for CPU core voltage
8.6. Assert PWM for CPU core voltage
8.7. Check CPU core voltage
8.8. CPU core voltage ready
8.9. Initial clock generator IC
8.A. North Bridge chipset voltage ready
8.C. 3VDUAL voltage ready
8.D. VDDA 2.5V voltage ready
8.D. GMCHVTT voltage ready
8.E. Check CPU fan speed
8.F. Assert all power ready
9.0.
Complete uGuru initial process
AWARD BIOS take over booting job
Power Off Sequence
9.1. Start power off sequence
9.2. De-Assert all power
9.3. Se-Assert power on
9.4. De-Assert LDT Bus power
9.5. De-Assert PWM for CPU core voltage
9.6. De-Assert CPU core voltage
9.7. Check CPU core voltage
9.8. De-Assert ATX power supply
9.9. Complete power off sequence
Others
F.0. Button reset
F.1. SoftMenu reset
F.2. Power on sequence timeout
F.3. Power off sequence timeout
NOTE: The decimal point lights up when executing the AC2003 POST  action.
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
Try seating it in another available slot. It can be a good idea, worth trying. Install the drivers once more.
    HP tx2001au Entertainment Notebook PC
    AMD Turion TL-58 64x2, 1.9 GHz
    2GB
    nVidia GeForce 6150 Go (128 MB)
    Hitachi 150 GB
what do you have "innit display first" set to in bio
edit,................. seems its a common fault send it back...
http://forums.overclockers.co.uk/showthread.php?t=18059718
Originally Posted by hamiltonjames
Just checked as I power up the board says 8B. It doesnt progress past this when it reboots. This is apparently Invoke all ISA adapter ROMS, Invoke all PCI ROMs (except VGA).
Same as mine. Unfortunately you and me are both victims of the wide-spread gigabyte EX58 a lot of people are complaining. After happening to me i investigated and there's a lot of info around.
I sent mine for RMA, as OCUK said that code 88 means trouble.
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
