You should upgrade or use an
alternative browser .
hi i am wondering if there is any way of getting aero to work on a ati radeon 9200se graphics card?
custom built
amd athlon xp 2600 1.92 ghz
msi
1.25 gb ddr
ati radeon 9200se
٩(͡๏̯͡๏)۶
Hello biesty and welcome to the forums
No, not the normal way anyway. Your graphics card isn't powerful enough to run aero, and it isn't supported in your drivers as the Radeon 9200 doesn't support DirectX 9.0, you have 8.1. You can use various customisation software to mimic the effect though:
Windows 7: Aero Glass Without WDDM Drivers ~ What the.....?
Tom
Build #1
Intel Core i7 3770K @4.4GHz
ASUS P8Z77-V PRO
Integrated on motherboard
23" LG LCD/LED IPS
1920*1080
Samsung EVO 128GB SSD
Seagate Barracuda 2TB 7200rpm
NZXT Phantom 410
