OK, as a precaution, I went to do a full complete backup of my RAID 0 drives, using Acronis True Image 11 Home ( it was offered here at a discount ) It was almost all done then got an error that it couldnt read a sector, which made Intel Matrix call out a failing HD. HP has hardware diagnostics that show no errors ( ran it twice ) I want to run check disk utility, can someone point me to a tutorial? Acronis said to try to check the disk and remove or repair the sector, ( can this be done on a RAID 0 configuration? ) and, if it cant be repaired to go ahead with the backup using the ignore bad setors option, then replace the drive. The machine is still on extended warranty so the drive is still covered, but just seems strange that i've no problems.. no reported errors from the diagnostics, ( it runs weekly ) even as I check it over and over got no errors, suddenly go to back up for the first time with Acronis and bam.. theres a drive failing. Please be so kind as to help instruct me on the chkdsk utility so I can see if errors are present using this utility.. then I can hit up HP with some facts when I call them back tonight. many thanks to all in advance.
- Q9550 2.83 Quad
- 8 GB OCZ 800MHz
- Nvidia 9800 GT 1GB
- LG 24
- 2 500 GB 32MB Seagate( Raid 0 ) 1 1000 GB 32MB Seagate
- PSU
- PC P{ower and Cooler 1000W
- Other Info
- HP d5000t ATX CTO
