Hard Drive Question.
pinakfans
If the hard drive is damaged, faulty. or just "went out" will that prevent the laptop from starting? Or can it still start? to login etc?
    Toshiba A135-S2345
    1 GB
    140 GB
If the harddrive is dead, you won't be able to boot into windows.
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
Ok thanks I was wondering. At first I though my motherboard was down, it could be the hard drive. The laptop starts it just freezes at the logo and makes popping sounds
    Toshiba A135-S2345
    1 GB
    140 GB
Use any linux CD and boot from the CD reader (change the boot sequence in the BIOS). Then you will see whether the PC still functions without the HDD.
    Dell
    Q6600
    HP w2207h
Depending on the manufacturer of the unit, you could also try running a HDD/Memory diagnostic from the BIOS. If it is POSTing, however after post freezing you could very well be looking at a faulty HDD. If you hear a clicking noise, it is most likely the actuator arm within the HDD itself, it's usually the first thing to go out.
