Help Adjusting Folder View
talon191
I looked for this under control panel but couldn't find options anywhere.
I want to set a default folder view properties, so that EVERY time I create a 'new folder' it always opens them with same viewing properties.
Example: "View > Details" (Not thumbnails), "Column > uncheck Tags, uncheck Rating, uncheck Date Taken, ect."
Is there anyway to set default folder properties as mentioned above?
That will most likely solve the problem I experience sometimes when mixing different file formats audio and video into the same folder and that folders window's view get reset.
Thanks much. Your a pro lol
If you find a way to make all newly created content always emerge in detailed view (not thumbnails) please let me know.
Your welcome Talon.
Using Method Two in the tutorial will set everything to use the All Items folder template, so it should have a created New Folder open with detailed views for you.
