Help Appreciated
"A malfunctioning or malicious add-on has caused Internet Explorer to close this webpage"
This is a 'Data Execution Prevention' related issue.
This comes up everytime I try to play an MSN Game online and closes my window. Ive looked up the pages on DEP and I am very confused. If anyone could help out (using small words....)
Thanks so much!
Thanks so much!
Hi and welcome to vista64
No problem. DEP data execution prevention is to prevent malicious code from using a memory overflow from launching an attack. DEP is located in your system control panel, under advanced system settings>advanced>... see enclosed picture. If you keep getting dep errors you want to make sure it is on for all programs, but if one, or two programs cause most of the errors (like a game) you can make an exception allowing that game to page out of memory. Forget all that.
Add whatever program is generating the errors to the exception list. the errors should stop
As a disclaimer. Make sure you have a working industrial strength anti-virus app running with current virus definitions.
Hope this wasn't completely off the wall for ya
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Thanks for the welcome!
Ok, This is where I get lost. I get a giant list (sys32) folder and Im not sure which one to add to my exception list. I cant find anything like IE or Explorer or anything named similar
thanks
thanks
Don't add iexplorer.exe. Add the malfunctioning program. Do the faq's say anything for the app?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
