Help!! booting from backup????
awaisagha
Banned
hi guyss
i want to know something...before i asked a Q that i want to make backtup of my pc C drive so i dun have to install OS just i run the backup...n many voted for acronis tre image software...i also found it on top ten reviews website...it was ranked much above...
but there is still a confusion,i was thinking how it will happen....and i got to know some Qs in mind which i want answe...
1.the acronis true image will form back up of C drive(including OS+drivers+softwares+settings) and store in the form of .iso file? m i saying right...
2.that iso can be installed from in same way as i install OS,i mean same booting dvd/or usb method...or it needs some special way(as norton ghost did,using bootable ghost n then run image)
3.suppose that image is stored in another partition of my computer in which i have stored all ISO files...how can i run that particular image from boot menu...cuz i dun know how to open command prompt from DOS,once it was easy when win98 was only OS...but now i dun know how...
(m asking this cuz i guess this image will be huge size n i have only 8gb usb...thats y asking how to boot it from that partition containing other iso too)
hi guyss
Hi and welcome
1-It will back up everything. I am not sure if it is ISO format or acronis proprietary format.
2-No you cant "install" and ISO. You can restore it. You will need the acronis boot dvd.
3-You boot from the restore dvd point it at the file you want to restore. The acronis backup will be as large as the partition where your OS is.
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
