Help - can't boot from cd
andrea121
Trying to wipe my computer, start w/ vista disk in and it goes to a black screen that says "Boot from cd:". sounds great, but nothing happens no matter what key I hit. Then the computer goes into a a regular start. Please help, not very technical and can't afford to take it in! Thanks.
Alright - now it says No boot available Press Enter Key to retry. I press enter and it goes back to the same message. press enter again and it says Boot from cd: try hitting enter and nothing happens
Were you able to get into bios?
This is what I think
Read the instructions again very carefully. Be sure that you understand how to use bios to change boot order.
If you are sure you did it correctly. I say that the CD may be bad.
Complete message is:
Boot from cd:
no boot device availlable, press enter to retry
SATA-0: Installed
SATA-1: Installed
SATA-4: None
SATA-5: None
Give me the exact mfg and model of your computer.
i will see what I can find out. Will post as soon as I get something.
