Help!! I cannot get past Startup Repair
Big Blue
Hey everyone,
I first encountered the problem this past Thursday. My laptop had been running fine for a while, but now when I start up all I get is startup repair, and it is unable to repair automatically. I believe it is an issue with the hard drive and I will list the problem details below.
I checked out the post about how to ask for help so I will try to do that to the best of my ability now...I have enough experience with computers to fix very basic problems and my family usually asks me for help, but I would not consider myself anything close to an expert. I am not very familiar at all with the command prompt which is something that many of my google searches suggested using. Some of the suggestions included using scannow and chkdsk, but I am unable to do either, because of a system repair pending and something about the volume respectively. Even the suggestion of going through regedit to BootExecute doesn't work because I don't even see BootExecute listed above CriticalSectionTimeout :sleepy:
When I last was able to log in, I wasn't doing anything out of the ordinary, just using the internet to check my e-mail and fantasy sports teams. I've thought maybe charging my iPod the day before and then not removing it correctly could be the problem, but I've made that mistake before and still been able to log on the next day. No matter what I do, I cannot get past startup repair. I've tried all three safe mode options, last known good configuration, and disable automatic restart on system failure. I also tried to do system restore, but it keeps saying I have no restore points, which I believe is BS b/c whenever I've had an issue in the past but still been able to log on, I've been able to select between 2 or 3...but I digress. I do not currently have my files backed up and I do not want to restore to factory default and lose everything on my laptop - pictures as well as Excel and Word files are the primary things I care about saving.
Here's as much information as I know at the moment - let me know if you need more specifics:
OS: Windows Vista x64
Laptop: Dell Inspiron 1520
BIOS Version = A03
Intel Core2 Duo processor
160 GB HDD
Don't exactly know if this affects the problem I'm having, but my memory shows I've installed 2048 MB out of 2046 MB available...yikes
Then here is the problem details I get from startup repair:
Problem Event Name: StartupRepairV2
Problem Signature 1: Auto Failover
Problem Signature 2: 6.0.6000.16386.6.0.6001.18000
Problem Signature 3: 6
Problem Signature 4: 1966109
Problem Signature 5: CorruptFile
Problem Signature 6: CorruptVolume
Problem Signature 7: 0
Problem Signature 8: 1
Problem Signature 9: Chkdsk
Problem Signature 10: 0
OS: 6.0.6000.2.0.0.256.1
Locale ID: 1033
Lastly, when I was running tests through the diagnostics, this is the error code it gave for the Hard Drive:
Error Code: 0146
2000-0146
Please help!!! If you need any additional info let me know.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
What happens when you boot into safe mode? It is suppose to list drivers and they are loaded. What is the last one listed before it stops loading?
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
    8 gb
    1 TB & 500 GB
