HELP! I have a virus...
bennys
Hello!
First of all, MOD or ADMIN feel free to move my thread to the appropriate forum please.
First off, here is my computer LABTOP information:
WindownVista Home Premium
Service Pack 1
System:
Manufacturer: Hewlett Parkard
Model: Compaq Presario C700 Notebook PC
Processor: Intel(R) Penttinum(R) Dual CPU 12370 @1.73 GHz
Memory (RAM): 1.00GB
System type: 32-bit Operation System
My computer keeps shutting down and destroyed everything in the Control Panel. I'm using (IE & FF3) and they keep shutting down. I ran AVG and it shows that I have an infected virus "win32/Heur".
I don't have anthying important saved on my labtop that I care about. I basically use it for surfing the net. I purchased it 4 months ago. My questions are:
  1. It did not come with the Installation Disk(s), It was pre-installed. How can I re-install everything that if it was the same way when I purchased it?
  2. If I reinstall (reformat), will my labtop still be infected with the virus?
Thanks for any help.
Goto start menu/ Pc Help & Tools/ then Recovery Disc Creation you will need 2 DVD-R's and follow the instructions to make your recovery discs.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Correct me if I'm wrong. I click on start>Help and Support>typed in PC Help & Tools. I can not find the Recovery Disc Creation anywhere. Must I purchase the Installation Disc?
Thanks.
Start menu/ all programs/ scroll down to pc help & tools/ then recovery disc creation
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Go here if its not in the start menu
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
No problem bennys
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
