help installing files from external hardrive
patch41
Vista Pro
hi i am a novice at this and would apreciate any advise you could give,i have a hp vista home premium 32 bit pc.i backed up my files onto an external hardrive as i have read was the proper thing to do.i think one of my downloads was infected with a trojan horse so i tried a system restore,that did not help,so i did a system recovery back to factory settings i would now like to install my files from the external hardrive but i dont know where to begin as i understand when they get backed up on the hardrive they are in a compressed state if someone could please explain in simple terms, as i said i am still in the learning process and any help would be greatly appreciated....than you.
What external hard drive did you use?
Did you actually compress the files with a compressions program when you backed them up? If not, then they don't need to be decompressed, and thus you can just move/copy them to when they belong.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
hi sygnus21, and also brink,
i did not compress them and its a western digital 500 gb hardrive which shows up as my-book-drive-k on the computer so if i am reading you right i just copy the files from my book and paste in drive-c,...and thanks a lot for the advise...patch41
Patch,
It depends on how you backed them up.
If you just manually copied the files one by one to the "my book", then yes you could just manually copy them back the same way.
If you used the Backup Files feature in Vista, then you will need to use the method in my post above instead.
If that's how you moved them over to the the drive, then yes.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
thanks shawn,
yes i did use the vista backup feature,once a month it would remind me, but when i click onto your (restore backup files) in your reply nothing happens could you be a little more specific on how i could get to that tutorial(restore backup files and thanks for your time and help...patch41
hi shawn,
been trying for the last few hours, been trying from the advise you gave restore backup files tutorial which i found very informative but no luck i kept getting the following message.the backup file could not be found check your hardware configuration or try a different backup.. error (ox8100001a) is there a way i can manually restore wiyhout vista or any suggestions...thanks patch41
Hi patch 41,
As you have effectively replaced the old backup program when you "recovered" to factory settings, the Backup program you have now will not have the old log Files. It does not know where the backups are.
You should be able to use the Search function - step 5 in the tutorial to Browse to the location of your your backups.
Hope it helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
