Solved help me please?!
Smurfyy
Danny :)
Hi all, hope everyone is well and everything is going like it should.
I got a bit of a problem, today i finished come coursework and tried to print it from my computer, but it didnt print, so i went to my mums computer and plugged my pendrive in.
so up comes the autoplay box (Win XP) and i click browse files, so all my files come up and i go the the folder where the document is. so i hi-light the folder and a box comes up saying its deleting the folder.
It gets to about half way deleting and i realise what it is actually deleting, all my coursework, so as you would imagine im sitting there, thinking "OH FORK", so it deletes and that was the end of that.
So i leg it into my dad and tell him whats happened, so he used this program called 'Power Data Recovery' and all of my deleted items on the pen drive pop up. so i plug it back into my computer and re open the documents to make sure they are still there and they all came up in this dodgey symbol writhing *ill attach a pic*
is there any was possible that i can get these files back to how they were before?
thanks in advanced, Daniel
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Just a guess here, What happens if you choose Windows(default) and then ok?
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
Hi, thanks for the quick reply, it just comes up with the same in the box, just spaced out over 62 pages...
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
We are going to try again :huh:, ill post back with the results
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
    Asrock P67 Extreme4
    auria eq2367
Whatever you do DO NOT copy ANY files onto that memory stick. This will permanently overwrite your coursework.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hi! still not working, derekimo, it is word 2003, and thanks both for taking time to help me, :)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Hi Daniel,
Sorry for my rushed last post! It is worth trying several different recovery tools, one will sometimes work better than another one. Here is a good free tool: DmitryBrant.com » DiskDigger and here is a very famous, good free tool: Recuva - Undelete, Unerase, File and Disk Recovery - Free Download and here is a list of free tools: Free Data Recovery, File and Partition Recovery, Undelete and Unformat Utilities (thefreecountry.com).
I wish you good luck with the recovery process. If a light scan does not do the trick try the deepest scan possible, even though it will take longer.
Good luck,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
    Asrock P67 Extreme4
    auria eq2367
thanks Richard, the one we used was Recuva, we used the un delete and the deepest scan, all the coursework is scattered in different parts of the pendrive, but i can see it and it is there. The problem is that it is all coming up in diamonds and squares when i open it up in word.
Just tried to copy it to my mums pendrive as she works at my school and said that she would see if our network admins can do anything about it, but it just kept saing that the files were corrupted and it couldnt copy.
i really think that i have lost them for good :cry:
Daniel
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
    Asrock P67 Extreme4
    auria eq2367
Hi Daniel,
As an afterthought, try all the recovery procedures on the computer you used to write the coursework, in the directory you had it saved in. Ideally, run the programs off a CD or another pen drive if you can, though chances are it won't make a difference if you don't.
Really sorry about that.
Richard
P.S I know that you won't want to hear this now, but next time, back up your work to your Hard Disk (ideally in two locations), your memory stick, and something like Skydrive: skydrive.live.com/ You use the same login as your Hotmail account(it's free)
Good luck,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Good for you Daniel,
Glad we could help you out.:D
    Asrock P67 Extreme4
    auria eq2367
Well that is really good news :party::party::party: I think that a big congratulations should go to Derekimo and all the work he has put into this thread and forum. Well done again,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Richard
Thank You Richard, I'd like to think it was a team effort. The Best Part is that it Worked!:D
    Asrock P67 Extreme4
    auria eq2367
Yess, thanks again, i cant explain how relieved i am :D
And now i can go to sleeps thinking about how great the Vista Forums are!
Daniel :D
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
That makes it all worth it Daniel, And Your Welcome.:D
    Asrock P67 Extreme4
    auria eq2367
derekimo -
That was well done Mate! Good and patient problem solving....I hope you get deserved Rep. out of this effort.
Daniel :D
Daniel -
You are very fortunate that derekimo has ensured that you can 'sleeps' soundly tonight.
I hope that this teaches you the value of doing backups for all that you do.....one simple click is all it takes to save everything that is of importance to you, and you from an avoidable and complete disaster.:shock:
I hope that anyone reading this post, learns from the fundamentally basic mistake you made.
Backup, Backup, Backup!!
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
derekimo -
Daniel :D
Daniel -
Backup, Backup, Backup!! ;)
Thank you sassofalco,
Yes rep was given, But such praise from a fellow member is very warming.
I am going to use that. Thank You!:D
    Asrock P67 Extreme4
    auria eq2367
