Solved Help me remove Display Driver Problem?(BB Flash Recorder)
Ptneo
I downloaded BB flash Recorder and it installed a "Display Driver" into my computer.. and it started to mess up my computer.. Such as: The icon in my browser displaying as a "page" right next to the url.. and the worst part about this was youtube not displaying properly.. (I try to enlarge the vids and it lags, sometimes when i do enlarge it It gets a blackish covering) The problem was bb flash Recorder being downloaded.. on My Vista Home Premium 32 bit system.. Can anyone help me uninstall everything? i tryed to uninstall BB Flash, but the Display driver stayed..:sarc: If i need screen shots to be put up, i will.. just ask me.. thanks for reading and for your time..
It should work. I do wish you luck because you may not have a restore point.
What I mean is that you must have a restore point that is before the problem began. I think that is explained in the tutorial.
Seems that you sorted your problem, glad that you did. Thanks for the rep.
