Solved Help: My Documents Will Not Open - Crashing
Hello Nekru, and welcome to Vista Forums.
Since this just happened, you might do a System Restore using a restore point dated before this problem to see if it can fix this for you.
Welcome Nekru, Have you installed any new programs? have you tried to enter the folder in safe mode? Try system or registry restore..
Edit: Update us!
You're welcome Nekru. I'm happy to hear that you got it sorted.
