Help needed
Rantej
My HP does not give me an option of system resume after improper shut down due to low battery, it used to come up with that option before...
can some explain why is this not coming up??
Hello Rantej,
Check that there is no change in your power settings.
When you have an improper shutdown, system files can become damaged, and so need to be repaired.
Open a command prompt as administrator and type sfc/scannow press enter and let it scan, if errors are found, you will need to scan again, until clean.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thank you for your reply.
I have changed the battery settings to default. it dint help.
I have run the command *sfc/scannow*, after the scan it shows
"Verification 100% complete.Windows resource protection found corrupt files but was unable to fix some of them.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log"
Can you please explain what that means??
Regards
Rantej
Welcome
It means that some of the files still have problems or are corrupt, as Stoney explained. If you have run it only once, run it several more times. It may take more than one run to fix the corruption. In many cases this procedure does not fix the corruption and other measures must be taken.
