Help needed
vistauser1111
Suddenly my laptop stated there is a potential threat and needs to run chkdsk. After running chkdsk it displays message - " windows has finished checking your disk Please wait while your computer restarts "
But it freezes and not rebooting at all.
I tried forced shutdown but then again it goes to chkdsk and freezes again.
My laptop is refurbished Sony Viao, 2 yrs old, using vista home
I really appreciate any help here.
Thanks a lot.
    1920 x 1200 pixels
Thanks Lorien !
But am unable to login to my computer.
I cant store the specified file since am in another laptop.
I dunno how this thing happened. I logged on to facebook, suddenly the potential threat which is severe window popped up.
Then I forced shutdown, windows booting says winlogin.exe corrupted, then goes to chkdsk, freezes on message - " please white while computer restarts "
Is this issue solvable ?
Or should I need any professional help here ?
It's much too early to tell if we can solve it together or if you need to take it in for service. Since that costs money (unless it is under warranty - if under warranty, contact the manufacturer immediately and submit a claim and keep in mind that anything you do may void that warranty so if they'll fix it for free, take advantage of that - but make sure you backup your data first as they may wipe the drive clean while servicing it), we'll try these steps first before reaching that conclusion.
We'll need to do a general troubleshooting to see if we can identify and resolve the problem. Skip any steps that require booting into normal mode for now and then reply with results. Use the disk or safe mode where required (if unable to boot into safe mode either (repeatedly pushing F8 during bootup until the menu appears and then selecting a safe mode option) – you should at least try to see if it works, preferably safe mode with networking, skip those steps as well).
Do you know when this problem began? Try a System Restore to a point in time BEFORE the problem began. Here's the procedure: http://www.vistax64.com/tutorials/76905-system-restore-how.html. Be sure to check the box to show more than 5 days of restore points. If the first attempt fails, then try an earlier point or two. NOTE: You will have to re-install any software and updates you installed between now and the restore point, but you can use Windows Update for the updates. Use the recovery disk if the system prompt doesn’t work. The recovery disk works a bit different from the above procedures but if you follow the prompts from the System Restore menu option with the above information you should be able to restore with no problems.
If the System Restore doesn't work, do a Startup Repair by booting to the genuine Windows Vista Installation Disk (or one you can borrow from ANYONE) or from a Recovery Disk with recovery options included on it. Here's the procedure: http://www.vistax64.com/tutorials/91467-startup-repair.html. To boot to the CD you may need to change the BIOS to make the CD-drive first in the boot sequence. To do that, wait for the screen that tells you the F key to push to access the boot menu or boot setup. Push it quickly. Make the changes, save your work, and exit. Put the CD in the drive and reboot. When prompted, push any key to boot from the CD.
If you don't have either disk, you can make a bootable Recovery Disk using
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/ along with burning software like: http://www.snapfiles.com/get/active-isoburner.html and, of course, a blank CD (perhaps made on a different computer or perhaps in safe mode with networking if that is working).
If that doesn't work, try to boot into safe mode (repeatedly click the F8 key while booting and go to safe mode with networking – or do so from the command prompt on the disk). Then let's check some of your system files:
Go to Start / All Programs / Accessories / Command prompt and right click on command prompt and click run as Administrator (you can skip this step if using the disk).
If using the disk, cd to C:\Windows\System32. Type sfc /scannow and enter and let it run. It will scan and try to fix some of your system files. Hopefully it will complete with no corruption it could not repair (if there is such corruption post back here or try to analyze it to find the problem file(s) using
http://support.microsoft.com/kb/928228. Try to attach the report (you may need to copy it to your desktop before it will permit you to attach it) here so we can see if they can be repaired with good copies from the installation disk (unless there are too many).
While in Command Prompt, type chkdsk /f /r and enter and let it run. It will want to schedule itself to run at the next restart. Answer yes and then reboot to run the program. It will scan and try to fix any corruption or bad sectors on your hard drive and mostly remove that as a potential cause.
If that doesn't work, then please post any error messages from the Event Viewer concerning startup (Start / Control Panel / Administrative Tools / Event Viewer). Here's how to use Event Viewer: http://www.petri.co.il/vista-event-viewer.htm. Look in the System section.
You may be infected with malware. Try to run anti-malware programs (in safe mode with networking if necessary). To fix this problem (if it is a problem) download, install, and run the following two programs: http://www.malwarebytes.org/mbam.php and http://www.safer-networking.org/en/index.html. You may also want to try a free trial of Pandasoft (http://www.pandasecurity.com/usa/homeusers/solutions/global-protection/). Before downloading pandasoft, uninstall whatever anti-virus program you are currently using (because installing and running two at the same time can cause conflicts, freezes, and all sorts of problems). Use removal tools when appropriate http://www.raymond.cc/blog/archives/2009/05/05/comprehensive-list-of-uninstallers-or-removal-tools-for-antivirus-software/. Once you've uninstalled your current AV program, download, install, update, and scan using Pandasoft. I think you might be amazed at how much it finds that the other software missed. Once complete, uninstall pandasoft and re-install your current AV program. You may also want to try the new, free Microsoft Security Essentials http://www.softpedia.com/progDownload/Microsoft-Security-Essentials-Download-131683.html (with the same caveat that only ONE AV program can be installed and running on your system at any one time). You may also want to try the free Avira at: http://www.free-av.com/ and Avast at: http://www.avast.com/index. Reboot after completing all the scans. You may also want to try the free OneCare at http://onecare.live.com/site/en-us/center/whatsnew.htm and let it run all the options (except the registry cleaner) because that’s good maintenance (it will take some time to complete but can be done in the background).
If that doesn't work, try a clean boot http://support.microsoft.com/kb/929135. If the problem goes away then it's just a matter of tracking down the culprit causing the problem. Follow the procedures in the article. Once found, delete, remove, deactivate, or uninstall it. Once done be sure to reset Vista back to normal status as explained in the procedures. If the problem occurs in clean mode then just restore the system to normal status and reboot - this solution is not going to work.
If that doesn't work, we'll need to do a system repair/upgrade using the genuine Windows Vista Installation Disk (one you own or one you can borrow from ANYONE). To do this you have to also be able to boot normally. Here's the procedure: http://www.vistax64.com/tutorials/88236-repair-install-vista.html. Although this will not affect your data, settings, or programs, you should still backup your data before starting just to be on the safe side. You may have a lot of updates to re-install (including any service packs you had to remove). If the version on the system came with SP1 or SP2 pre-installed and the disk is an earlier version, then you'll need to make a slipstream disk as follows: http://www.vistax64.com/tutorials/151606-vista-sp1-slipstream-installation-dvd.html. Please reply before doing the next step as it is a radical option and I’d like to make sure we’ve ruled out all other options before taking that step.
If that doesn't work (or you don’t have the disk), then I'm afraid the only option is a clean install. You can use Knoppix http://www.knopper.net/knoppix/index-en.html with a good ISO copier like: http://isorecorder.alexfeinman.com/isorecorder.htm along with a blank CD. This should give you enough access to the system (if you can't get in any other way) to backup your important data. If that doesn’t work, try slaving the drive to another computer and recovering the data using that other computer to access the disk. Once done, you can do a clean install either using the genuine Windows Vista Installation Disk or the Recovery Disk or the Recovery Partition (whatever process is dictated by your computer manufacturer – you may need to contact them for the procedure and perhaps to get recovery disks). To do a clean install proceed as follows: http://www.winsupersite.com/showcase/winvista_install_03.asp (adapted as necessary by the procedures of your computer manufacturer). Then you will need to re-install all your programs, reset all your preferences, reconfigure your network and email settings, restore your backed up data, run Windows Update with possibly nearly 150 updates pending,...
Hopefully one of these procedures will resolve or at least identify the cause of your problem.
Good luck!
    1920 x 1200 pixels
