Help on disabling shutdown command
Alias D
Hey guys! I've been looking all over the Internet trying to find a solution to disable the shutdown command for certain users.
Please help me if you can!
Thanks!
Sorry Shawn, but I already tried that and the command prompt gave me this error:
Revoking SeShutdownPrivilege from Ben ... failed
AddUserRightToAccount:
***Error*** AddUserRightToAccount -1073741772
Hello!
Well, the mapping for that error code:
# for decimal -1073741772 / hex 0xc0000034 :
STATUS_OBJECT_NAME_NOT_FOUND ntstatus.h
# Object Name not found.
Maybe Brink has some ideas?
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I'm afraid that I'm not sure. It seems the error may be some sort of lack of permission or access??
Hmmm! I handed over to you because I wasn't sure! lol.
I would say, judging from your error code, that your "User or Group" is incorrect. What are you entering as your "User or Group" at the moment, and could you try something which you know is correct to test?
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I am using another regular account called "Ben" this is what I am putting in:
ntrights -U "Ben" -R SeShutdownPrivilege
I personally think it might be that the ntrights program is for xp and windows 2003 only.
