xsmallheartx
I was wondering if any one has overclocked a Q9450 on a GA-X48-DQ6 motherboard. I havent overclocked before and was wondering if I could get some advice on what settings to use. Also thinking of getting Zalman CNPS9700NT cpu cooler if I OC. If there is a better recommendation I would be glad to know.
I am not sure how much I should change the voltage, Vcore etc.
My specs are:
CPU: Q9450<O
</O
Mobo: GA-X48-DQ6<O
</O
Ram: OCZ Platnium 6400 (800mhz) 2GB x 4<O
</O
Case: Antec 900<O
</O
CPU fan: Stock
GFX: Gigabyte Radeon 4850
PSU: Thermaltake Toughpower 600W
Thanks,
<SCRIPT type=text/javascript> <!-- vBulletin.register_control("vB_ProfilefieldEditor", "1"); //--> </SCRIPT>
My specs are:
CPU: Q9450<O
</O
Mobo: GA-X48-DQ6<O
</O
</O
Case: Antec 900<O
</O
CPU fan: Stock
Thanks,
- Custom Built
- Intel Q9450
- GA-X48-DQ6
- OCZ Platnium (800mhz) 2GBx4
- Gigabyte Radeon 4850 512mb
- Samsung 2333SW
- 1920 x 1080
- Samsung SATAII 650GB
- PSU
- Corsair TX 750W
- Case
- Antec 900
- Cooling
- Stock
- Razor Lachesis
- Logitech Slim
