Help please! Tune up utilities installation!
help000
Banned
I keep getting an error messege every startup.
Heres a picture.
I use vista. I was installing Tune up.
My whole computer froze and I had to shut it down.
Next thing when I started my system no restore points a security program that I unstalled a long time ago was on my pc and now I can't unstall any and i keep getting the messege. I use vista. HELP PLEASE!
See if its still in msconfig and trying to startup auto on boot.
start search > type msconfig > hit enter > accept the UAC prompt > go to the Startup tab at the top > look for anything 'TuneUp' untick it then restart. See if that stops the error message.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
Help please! Iobit 360 Security!
Ok my comp froze in the insttalation in tune up utilities and now all my restore points are deleted because i restarted my comp by pressing the button on the cpu and somehow iobit security that i installed A VERYLONGTIME AGO and unstalled it is back.
it dosent show up in Windows unstaller.
when i try revo unstaller it says no installation package found
or i think it is because i was installing it yesterday and my av found a trojan and i quickly pressed cancel is that why?
How do i fix it?
Thanks to everyone that responds
It auctully comes every 5 min after start up too pleas ehelp!
Its not in startup
Re: Help please! Iobit 360 Security!
Please put your system specs in the lower left-hand corner of the frame.
Install mawarebytes and run a full scan. Repeat this again in safe mode.
What virus scanner are you running? What is the specific name of the virus you discovered? Update your virus .dat file and run a thorough scan again.
Where were you installing tune up utilities FROM?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Isn't malawarebytes 32 bit only like a-squared free ? I know the both have a good rep but i'm not sure on 64 bit OS. I had Superantispyware find some trojan the other day which you guys all recommended.
Iobit is pretty new for an antivirus suite ? I'm hesitant with new stuff when its that important.I like my Avast free its worked a lot better than Avira which I used for awhile.The scanning mode kinda sux but heh you can't have everything.
What do you think about Comodo ? Its firewall was a little 2 annoying last time I tried it out.
    gateway
    intel quad
    8 gig
    nvidia
    realtek
    19' widescreen
    1440 x 900
    581 gb
    High speed Comcast cable
I think a few people on this site were down on Comodo. I dont use it, so am not able to comment from personal experience. Again, on this site, we've been consistent on recommending malwarebytes.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
help000,
Second Notice:
Please do not keep posting mulitple threads about the same question. You need to keep them posted in the same thread for the same topic so all the help you recieve on this is together in one place to make it easier to follow.
All posts merged into this one.
Thank you,
