All of the last updates I received installed correctly except one entitled:
"Update for Windows Vista (KB972036) Recommended 8/25/2009".
I have tried to install it several times and always get this message:
"X Some updates were not installed.
"Failed: 1 update Error(s) found: Code 80070570
Windows Update encountered an unknown error."
What do I do to resolve this?
I would appreciate any help that anyone can give me. However, please explain things in basic terms as I'm an older computer user with only limited technical knowledge. :D I tried doing a search in this forum (which I just joined) but can't decide what applies to this problem.
Many thanks!
Many thanks!
I was about to mark it hidden as you suggested when a new Windows Defender definition update was received and successfully installed. For some reason, this apparently caused the KB972036 update to disappear. It no longer comes up when I check for updates, so I guess the problem is solved. Again, thanks for your quick reply!
