help please
harlza18
hi everyone....was tweaking my graphics card with Nervia and i was changing some options and now when i go into GTAIV it crashes say GTAIV FATAL ERROR "unable to create depth render target. please reinstall DriectX or install the latest video card drivers" i have tried switching everything to the defaults and i uninstalled it
what have i done??
i have updated my Direct X to the latest version and i am downloading the latest grapics drivers from Nvida
HELP!!!!
    Microsoft
    Intel Core Duo 2
    EP43-DS3
    E4800 @ 3.00
    Nvidea Geforce GTS 450
    Realtack high def
    BenQ T22IW
    1280X1024
    Maxtor STM 3320820AS ATA device
    logitch wireless mouse
    logitech wireless keybord
    running off a USB internet dongle
hm....... did you try uninstalling then reinstalling the version you were using when it last worked?
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
Go to the GTA4 shortcut, and right click it > Properties > Target.
In target it'll say for example: "C:\program files\GTA4\gta4.exe"
I'm not sure what it'll exactly say, but the quotations MUST be there.
add the code -swtnl to the end of the target.
It will look like similar to this.
"C:\program files\GTA4\gta4.exe" -swtnl
LEAVE THE QUOTATIONS... and don't copy from here and paste it in the target, type in -swtnl manually.
    AMD
    ATI
Go to Device Manager and then uninstall your Display Adapter driver. Then don't install the latest one from the manufacturer, but get the original driver (the one that was preinstalled). Probably you will get it on your PC manufacturer's site.
Probably you will get everything right. Then install the latest drivers.
    HP tx2001au Entertainment Notebook PC
    AMD Turion TL-58 64x2, 1.9 GHz
    2GB
    nVidia GeForce 6150 Go (128 MB)
    Hitachi 150 GB
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
i thogought gpu's were overclocked by the BIOS?
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
No mate you use the bios to overclock your CPU you can use software based applications such as Riva Tuner to overclock your GPU within windows :) Its always a good idea to do plenty of research first though and overclocking your GPU for the most part is usually a waste of time
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
+1:)
For OP: More on overclocking GPU - Link
Regards
    QuadCore Intel Core i7 920
    Intel X58
    12 GB Corsair XMS3 DDR3-1333 SDRAM
    Sapphire Radeon 4890 1GB xFire
    Xonar HDAV1.3
    Dell 2408WFP
    1920x1600
    2xVelociRaptor 150GB (OS) 1TB WD HDD (Storage)
    Corsair HX1000W
    Antec 1200
    Razer Lachesis
    Razer Lycosa
Okay.
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
