Help required
Any error messages?
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0 WD Raptor 36gb 3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
If I remember correctly, I was left with a number of legacy registry entries that I could not delete after uninstalling AVG.
I was going to reinstall Vista anyway - just did it a bit sooner to get rid of them. Have stayed away from AVG since.
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Rudie no need for multiple posts, you can edit what you've posted.
this is from wikipedia
Kaspersky Antivirus and Kaspersky Internet Security version 2009, forces users to uninstall Spybot during installation process, although there is no serious incompatibility yet known. The discussion was concluded in the Kaspersky forum, which said not to install Spybot at all. Kaspersky seems to be reluctant to fix the issue although they have received several complaints.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    Thermaltake Armor
    Tuniq Tower 120
